DATAGERRY 1.3.1 released
Today we released DATAGERRY 1.3.1, a small bugfix release. It fixes an issue with the DocAPI template helper button and an issue with the new category UI. Also we disabled the animation on the login screen, as it caused some performance issues especially in Citrix environments. Thanks for reporting all that issues and as always, if you found new issues or want to share your ideas for DATAGERRY, please open a topic in the Report a Bug/Enhancement category.
  • [NET-509] - Object template helper button calculates iteration not only on depth
  • [NET-511] - Category UI: Moving a subcategory to the top level is not possible
  • [NET-525] - Animations on Login screen will cause trouble in Citrix environments
