Hi!
In the Section Templates i can’t Label the Special Control - Reference. I can put in a Label but as i safe and test it, it is Called “Ref”.
If i manually Create the same combination in a Type, it works just fine.
I use DataGerry 2.2.0
Hi @Matt,
Thanks for the info. I’ve created a Jira ticket for it (DAT-1655) and will update you once the issue is resolved.
sincerely,
          Hi @Matt,
Thank you for bringing this issue to our attention. We’ve identified and resolved the bug, and the fix is scheduled to be included in the upcoming release.
sincerely,
