Cannot set Reference Label
When I create a Ref field, I set a name for the label, but it always stays named “Ref”:
Even if I go back to the type and change the name of the label to something else, it’s always saved as “Ref”
The only way I’ve been able to set the labels on references is to export the type to json, edit the json and import it.
Hi @edzilla ,
we were able to reproduce the issue and will fix it. Thanks for your feedback.
Perfect, thanks for the quick reply
