Section Templates
Good Morning, I hope everyone is well. I have noticed when creating a Section template it cannot be deleted. I have also notice that I cannot change the lable of a field when clicking save it just defaults to Ref.We are currently field trailing data gerry for a potential project
Indeed, I have the same bugs here. What I usually do as workaround is to export the definition of the object into a json, modify it in a text editor, as the json is really simple to understand, and then reload into DataGerry.
Thanks for the feedback,
the issue has been identified and fixed. It will be part of the next release.
