RELEASE Wrong ref text field summary lookup for reference
Scenario:
Type A has a text field “name” - this field is set as visible field in “summary”
Type B has a reference (from special controls in gui editor) to field “name” of type A
Problem:
If I enter some text in field “name” at type A, save it and try to create a new object of type B and then select an object to be referenced of type A with certain text in field “name” the summary field is not correctly shown - i.e. other fields than the field “name” are shown.
Diagnostics:
This only happens for certain input in field “name”.
Here is the result of my tests (left the input, right the result):
app-study–3 NOT OK
app-study–3- NOT OK
app-study-A-3- NOT OK
appstudy-A-3 NOT OK
appstudy-A-39 NOT OK
app-study-A-39 NOT OK
app-study-A-A OK
app-study-A-A1 OK
app-study-A-A19339 OK
From the above I gather that the lookup mechanism does some regular expression matching for lookup with some hardcoded rules and trips over.
I think the broken algorithm there is:
“If the field contains a dash at the END of the name followed by at least one number - then go wrong
in all other cases - do it right”
Caveat: It might be that this problem does not occur in a fresh blank new database as I had to switch between release and current dev code several times. I had no time to test this yet.
Please fix this quickly (if it is reproducible at your developers) as this is an elementary functionality for entering data and would lessen the value of Datagerry significantly!
Thanks for the info. I’ve created a Jira ticket for it (DAT-1545) and will update you once the issue is resolved.
Best Regards,
Abdullah
The issue has been fixed — the bug is resolved in the current dev version. Thanks again for your detailed report!
Best Regards,
Abdullah
