could you please omit the confirmation info box which for several seconds blocks the selection of the buttons in the upper right corner? Think it’s ok for errors, but: no news is good news ![]()
In addition, please prevent the “Getting started” box from popping up every time when selecting lists like the type list and the exportd job list for example. Or did i miss the option to do so?
Thanks for your work!
Kind regards, Michael
Hi @MiB ,
thanks for your input. We regard is as important to display feedback on an action but you also got a point.
I will add the points you mentioned to our backlog to reevaluate it.
Hi @MiB ,
as part of the next update the “Getting started” box will be removed and for now the message boxes in the top right corner are moved a bit down to prevent overlapping the buttons in the top right corner.
It is also possible that we will redesign the mesaage boxes in the future and replace them with a designated area for messages.
Thanks for your feedback which helped us improve the usability of DATAGERRY ![]()
