DATAGERRY 2.0.0 release
We are happy to inform you that next week the new version 2.0.0 of DATAGERRY will be released.
Here is an overview of the changes:
DATAGERRY 2.0.0
New Features
Locations
  • The sidebar now contains a new Tab “Locations” where locations are displayed in a tree structure
  • Added new Special Control “Location” for types which enables types to be assigned to locations
Assistant
  • Reworked initial assistant
  • It is now possible to select branches and profiles and DATAGERRY will automatically create the corresponding types for a quick start
  • Added a link to the assistant in the toolbox (Toolbox => Assistant) so that it is possible to start it manually
Changes
  • Rework of the Feedback-Form (Toolbox => Feedback)
  • When creating or editing a type it is no longer possible to proceed to the next step (or press the “Save”-button) if this step has invalid fields
  • Added an “x” to be able to clear the filter input in the sidebar
  • Types are now only deletable if no object instances exist of this type
  • Dropped support for python 3.6, 3.7 and 3.8
Bugfixes
  • Fixed a bug displaying popup boxes behind the gray overlay background
  • Fixed an error where the progress bar of a toast was not animated(Popup confirmations in the top right corner)
  • Fixed a bug where saving a column config the input field would get an invalid red border. The red border now correctly only appear if the input field is empty when clicking the save button
  • Fixed a display bug in Exportd list where the column name was “Name” instead of “Label”
  • Fixed an error where Links between objects where not displayed in the object overview
  • Fixed a bug where the filter in the sidebar did not hide “Uncategorised” Types if the filter-input did not match
  • Fixed an occurring error when pressing the “Show Tabs” button in the object overview when the object didn’t have any references
  • Fixed a bug where object counters where not correctly updated when switching between “Only Active Objects” and “All Objects”-Mode
  • Fixed a display bug where other elements overlapped the sidebar when in cropped view
  • Fixed an error when copying dates to clipboard resulting in output to be [object Object]
  • Fixed bugs with the “Save” and “Cancel” button when creating new categories not working as intended
  • Fixed an error occurring when closing popups via the “x” in the top right corner at several places in DATAGERRY
  • Fixed stacking counters when interacting with bulk changes
  • Fixed an error appearing when pressing to often and to fast references in object overviews
  • Fixed a bug falsely displaying an error when objects are exported
  • Fixed a bug where multiple clicks were required to change the order of a table column
  • Fixed a visual bug where the scroll bar on text area fields was to small to be selected
  • Fixed a visual bug for the type overview on the dashboard
  • Fixed a visual bug hiding the filter field in the sidebar when cropping browser to mobile view mode
  • Fixed several occurrences where parts of the application were not reloaded after changes took place
  • Fixed a bug which cleared the table when clicking “Default configs” in object list
  • Fixed a bug where the sidebar was not reloaded after deleting a type and still showing the deleted type
Frontend Changes
  • Bumped Angular packages to 15.2.4
  • Bumped Angular package dependencies to fit Angular 15.2.4
Backend Changes
  • Bumped Python to Version 3.9.16
  • Tests are run against MongoDB 4.4, 5.0 and 6.0 with Python 3.9 (Dropped tests for Python 3.7, 3.8 and MongoDB 4.2)
  • Added location logics to backend
  • Deleting an object with also delete the corresponding location
Python Package Bumps
  • alabaster to 0.7.13 (from 0.7.12)
  • altgraph to 0.17.3 (from 0.17)
  • astroid to 2.15.5 (from 2.5.1)
  • attrs to 23.1.0 (from 20.3.0)
  • Authlib to 1.2.1 (from 0.15.3)
  • Babel to 2.12.1 (from 2.8.0)
  • blinker to 1.6.2 (from 1.4.0)
  • Cerberus to 1.3.4 (from 1.3.2)
  • certifi to 2023.7.22 (from 2020.6.20)
  • cffi to 1.15.1 (from 1.14.3)
  • chardet to 5.1.0 (from 3.0.4)
  • click to 8.1.3 (from 7.1.2)
  • coverage to 7.2.7 (from 5.5)
  • cryptography to 41.0.1 (from 3.4.7)
  • docutils to 0.20.1 (from 0.16)
  • et-xmlfile to 1.1.0 (from 1.0.1)
  • flake8 to 6.0.0 (from 3.8.4)
  • Flask to 2.3.2 (from 1.1.2)
  • Flask-Cors to 4.0.0 (from 3.0.9)
  • gunicorn to 20.1.0 (from 20.0.4)
  • idna to 3.4 (from 2.10)
  • imagesize to 1.4.1 (from 1.2.0)
  • iniconfig to 2.0.0 (from 1.1.1)
  • isort to 5.12.0 (from 5.5.3)
  • itsdangerous to 2.1.2 (from 1.1.0)
  • Jinja2 to 3.1.2 (from 2.11.2)
  • lazy-object-proxy to 1.9.0 (from 1.4.3)
  • ldap3 to 2.9.1 (from 2.8.1)
  • MarkupSafe to 2.1.3 (from 1.1.1)
  • mccabe to 0.7.0 (from 0.6.1)
  • openpyxl to 3.1.2 (from 3.0.5)
  • packaging to 23.1 (from 20.4)
  • Pillow to 10.0.0 (from 8.1.2)
  • pluggy to 1.2.0 (from 0.13.1)
  • py to 1.11.0 (from 1.10.0)
  • pyasn1 to 0.5.0 (from 0.4.8)
  • pycodestyle to 2.10.0 (from 2.6.0)
  • pycparser to 2.21 (from 2.20)
  • pycryptodome to 3.18.0 (from 3.10.1)
  • pyflakes to 3.0.1 (from 2.2.0)
  • Pygments to 2.15.1 (from 2.7.1)
  • pyinstaller to 5.1.3.0 (from 4.0)
  • pyinstaller-hooks-contrib to 2023.4 (from 2020.8)
  • pylint to 2.17.4 (from 2.7.2)
  • PyMySQL to 1.1.0 (from 0.10.1)
  • pyOpenSSL to 23.2.0 (from 19.0.0)
  • pyparsing to 3.1.0 (from 2.4.7)
  • PyPDF2 to 3.0.1 (from 1.26.0)
  • pytest to 7.4.0 (from 6.2.2)
  • pytest-cov to 4.1.0 (from 2.11.1)
  • pytest-html to 3.2.0 (from 3.1.1)
  • pytest-metadata to 3.0.0 (from 1.11.0)
  • python-dateutil to 2.8.2 (from 2.8.1)
  • pytz to 2023.3 (from 2020.1)
  • reportlab to 3.6.13 (from 3.5.50)
  • requests to 2.31.0 (from 2.24.0)
  • six to 1.16.0 (from 1.15.0)
  • snowballstemmer to 2.2.0 (from 2.0.0)
  • Sphinx to 7.0.1 (from 3.2.1)
  • sphinxcontrib-applehelp to 1.0.4 (from 1.0.2)
  • sphinxcontrib-htmlhelp to 2.0.1 (from 1.0.3)
  • sphinxcontrib-httpdomain to 1.8.1 (from 1.7.0)
  • sphinxcontrib-serializinghtml to 1.1.5 (from 1.1.4)
  • toml to 0.10.2 (from 0.10.1)
  • urllib3 to 2.0.3 (from 1.25.10)
  • Werkzeug to 2.3.6 (from 1.0.1)
  • wrapt to 1.15.0 (from 1.12.1)
  • xhtml2pdf to 0.2.11 (from 0.2.4)
The new Version can be downloaded here:
bin/targz/rpm:
https://files.datagerry.com/latest/
docker:
https://hub.docker.com/r/becongmbh/datagerry
For more information about the new features read here:
