DATAGERRY - Version 1.6.3
NET-1088 Object log change display error
NET-1076 Error objects without summaries KeyError: 'summaries'
NET-1073 Type field definition synchronise with meta data
NET-1071 Evaluating two references within a section
NET-1070 Extend Field of interpolation by Object ID
NET-450 Object summaries with date fields are not handled correctly at some places
NET-1015 Admin Guide: Framework Types ( reference section and reference custom summaries)
Sub-Task
NET-1072 Highlight selected references in object edit mode
NET-1053 Create FormControl for simple References Summaries
NET-1052 Create FormControl for simple References
NET-1055 Adapt Simple-Reference-Field to the new renderer of the type generator
