Datagerry 1.7.1
DATAGERRY - Version 1.7.1
NET-1120 Can't save changes in type of object in version 1.6.6
NET-1103 References to deleted objects
NET-1100 Bulk Change chang all fields instead of one
NET-1099 Exportd Rights evaluation
NET-1090 Field was not found inside input_type
NET-1079 Summary in the search shows None for some objects.
NET-1065 Default values are not set
NET-1064 Reference section fields are not resolved during bulk change
NET-1063 Reference section fields are not resolved in the DOC api
NET-1061 Type generator: Predefined options are not loaded
NET-1060 Crash after change type without cleanup
NET-1057 Crash when adding 2 reference types
NET-1077 References ref-section-field to ref-section-field
NET-1019 Update y18n from 4.0.0 to 4.0.1
NET-1018 Update ngx-filesaver from 8.1.0 to 11.0.0
NET-1016 Documentation: Rest API - object routes
NET-1014 Admin Guide: Framework Object ( Exporter CSV etc. as RAW)
NET-940 Filter for Reference by Tab
NET-528 Autofilter for object tables
Sub-Task
NET-1113 BUG: Multi reference filtering
NET-1110 Documentation
NET-1109 Clean-out
NET-1106 Extend table by search row
NET-1097 Customize DocAPi (Templates)
NET-1096 Customize Object table export (customer Export)
NET-1095 Customize Exportd
NET-1094 Frontend: Create display for 'ref-section-field' elements.
NET-1093 Adapting the data structure for CmdbRender objects
NET-1092 Preventing references to self
NET-1091 Backend: Limiting the levels
NET-1089 Customise Pytest
NET-1087 Adding Step 'Complete'
NET-1086 Error handling
NET-1084 REST API Test Update
NET-1083 Remove deprecated update functions
NET-1082 Add Update-Many-Function
NET-1081 Move update function to the new object manager
NET-1080 Extension of the update response
NET-1066 Load number of objects when opening the category points
NET-1059 Apply reference field label
NET-1058 Reference Input Searchable
NET-1098 Equality check Search term
NET-1074 Object not found Exception handling for bulkchange
NET-1068 Admin Guide: Object tables filter
NET-1067 Search for reference field values at the object list
NET-794 Update python crypto packages
NET-640 Migrate object endpoint to new REST API: Delete
NET-639 Migrate object endpoint to new REST API: Update
