DATAGERRY - Version 1.6.2
NET-1065 Default values are not set
NET-1064 Reference section fields are not resolved during bulk change
NET-1063 Reference section fields are not resolved in the DOC api
NET-1062 Update blueprints for Object routes
NET-1061 Type generator: Predefined options are not loaded
NET-1060 Crash after change type without cleanup
NET-1057 Crash when adding 2 reference types
NET-1056 Error when copying objects with reference section fields
NET-1028 Empty referenced fields are filled with first object from object-list
NET-1016 Documentation: Rest API - object routes
NET-1014 Admin Guide: Framework Object ( Exporter CSV etc. as RAW)
NET-940 Filter for Reference by Tab
NET-1068 Admin Guide: Object tables filter
NET-1067 Search for reference field values at the object list
NET-1054 Making Section Reference Input Searchable
NET-468 Object counter in category sidebar
