We are proud to announce the release of DATAGERRY 1.6.0 , with many new features.
NET-1025 Display error reference fields (Preview)
NET-1024 Type builder deletes wrong field
NET-1023 Skip pagination reset
NET-1021 Deactivated types are not displayed as Uncategorized in the sidebar
NET-1012 Display error reference fields
NET-1004 Wrong timestamp while updating objects via CSV import
NET-1001 Active badges in dashboard tables not centered
NET-988 Field is undefined in the object view after adding a new field in the type generator
NET-987 Nullpointer when displaying changes in the object log list
NET-981 Render throws error when downloading template pdf
NET-980 User management registered since shows object
NET-979 Right management wont display any data
NET-978 Empty subscription handling in user settings sync
NET-977 Remove text centering from search bar
NET-975 Remove strict mode (momentjs)
NET-973 Text and textarea fields are imported as text ‘true’ instead of ‘1’ during a JSON import of objects
NET-972 JSON export of objects incorrect: Not all entries are exported correctly
NET-971 Selecting different radio fields with the same values is not possible
NET-968 Type route iteration failed with empty parameters
NET-967 Typo error in systemd config
NET-966 Field key ‘Value’ is missing in copied objects
NET-958 Authentification failed: Cross-Origin Request Blocked
NET-943 Display error dropdown submenu for the exportd template helper
NET-927 Pagination in the search is not displayed
NET-496 “Invalid Date” in object logs
NET-291 Deactivated types can still be used for creating objects
Epic
NET-952 Referencing field sections
NET-1006 Creation, Modification time and last modifier on types
NET-986 Complete objects list
NET-974 Check exportd condition value with regex and limit obejct transfer
NET-957 Reference display of sections
NET-956 DocAPI support for reference section
NET-955 ExportD support for reference section
NET-954 Searchable reference section
NET-953 Reference section as type field
NET-923 Store user settings for all tables
NET-910 Structuring references in the object view
NET-909 Dynamic reference summary functionality
NET-902 Search results displayed length
NET-900 Load all objects in the dashboard tables
NET-896 Extend search engine for references
NET-895 Return to last search page
NET-894 Session timeout notification
NET-825 Implement deactivation of types
NET-422 Refactoring of date handling in frontend
Sub-Task
NET-1011 Extend ExternalSystem with Event Output
NET-1009 Transfer only the objects that have been changed
NET-995 Restructure Backend
NET-993 Display matches
NET-992 Query: Merge reference fields into the object fields
NET-962 Using the global date settings for formatting date
NET-961 Create date settings component
NET-960 Create date settings service
NET-959 Cleanup date picker
NET-936 Store user settings for exportd logs
NET-934 Store user settings for object logs
NET-933 Store user settings for reference by (object view footer)
NET-928 Nested summary builder
NET-897 Frontend: Display of search results with references
NET-1026 Cleanup: Warnings browser console
NET-1022 Change from datetime.now() to datetime.now(timezone.utc)
NET-1010 Update dependabot assignees
NET-996 Refactor reference sections
NET-947 Test environment
NET-795 Update bootstrap
NET-726 Review framework aggregation workflow
NET-351 Upgrade Angular
