Hello everybody,
I noticed the following when maintaining objects in DataGerry:
Scenario:
- I have defined two types with a summary. The summary contains several fields.
- In one of these types, a reference field is stored that refers to the other type.
- Then I try to create or edit an object (also applies to bulk change) by setting a reference field and saving it.
- The object was saved, but the reference field is displayed empty in the overview and in Object View, Object Edit.
- If I now change the type of the summary so that it refers to a filled value, then I get the previously saved value for the reference field displayed in the Object View or Object Edit.
This behaviour suggests that there is a display problem when referring to an empty field in the summary. This could potentially lead to data loss if one relies on the display and saves the object again.
I recommend fixing this error promptly.
