Question for Becon gmbh: Next Datagerry release in June 2024 date?
Hi Becon,
  1. Have you got a specific date for the next Datagerry release? Is it in June 2024?
  2. Where is the release for 2.0.0? I cannot find this in Index of /latest/rpm Can you make earlier releases available?
  3. I should like to install the development snapshot from GitHub - DATAGerry/DATAGerry: Enterprise-Grade OpenSource CMDB with flexible data model.
The RPM contains 1 x binary file and 1 x config file.
However, the development snapshot contains 2040 different files. Do you build a binary file from the development branch? How can I build this?
Many thanks.
Hi @sink1 ,
  1. We are planning the next release for June 2024 but there are still some things which need to be implemented/adapted for the next version.
  2. You can see all releases at the following Link: https://files.datagerry.com/
  3. We are using the Makefile in the root directory to build all the different packages. It is not automated at the current state.
Hi Adnan,
  1. Good news about the release in June.
  2. Thank-you you so much for the link to the previous versions.
  3. Thanks. I worked it out last night. Just need to build it for an rpm.
Will this el8 version work also with el9?
https://files.datagerry.com/2.1.0/rpm/DATAGERRY-2.1.0-1.el9.x86_64.rpm
The link you send is an el9 version, so i am not sure what your question is.
But from version 2.1.0 and forward we will require el9 to build the RPM packages.
Typo error. I meant this:
https://files.datagerry.com/2.0.0/rpm/DATAGERRY-2.0.0-1.el8.x86_64.rpm
We have not tested that but could probably work.
