Hello everybody,
- I am exporting a CSV with objects
- I manually adjust a field called “my_referenced_field” in the CSV by entering a matching “Public ID” everywhere
- I import the CSV with the objects
- The objects were imported successfully
- The referenced field “my_referenced_field” is displayed correctly with the corresponding “Summary”
- I now navigate to the referenced object and am in “View mode” to look at the tab “Referenced by”. The list is empty.
The list in the tab “Referenced by” should not be empty. Here I expect the objects that have referenced this object. Unfortunately, this is not the case.
I assume that this relation was not taken into account when importing the objects.
Would you be so kind and correct this? Thank you very much!
