I use datagerry from zip package. My operating system is Ubuntu 22.04.
Datagerry starts normal nad works correctly after start machine.
Works after start
root@server:~# systemctl status datagerry
● datagerry.service - DATAGERRY - Enterprise grade OpenSource CMDB
Loaded: loaded (/etc/systemd/system/datagerry.service; enabled; vendor preset: enabled)
Active: active (running) since Tue 2024-07-02 11:27:23 CEST; 1 day 1h ago
Main PID: 1537 (datagerry)
Tasks: 37 (limit: 4556)
Memory: 1.1G
CPU: 10min 43.745s
CGroup: /system.slice/datagerry.service
├─1537 /usr/bin/datagerry -c /etc/datagerry/cmdb.conf -s
├─1546 /usr/bin/datagerry -c /etc/datagerry/cmdb.conf -s
├─1554 /usr/bin/datagerry -c /etc/datagerry/cmdb.conf -s
├─1559 /usr/bin/datagerry -c /etc/datagerry/cmdb.conf -s
├─1563 /usr/bin/datagerry -c /etc/datagerry/cmdb.conf -s
├─1564 /usr/bin/datagerry -c /etc/datagerry/cmdb.conf -s
├─1565 /usr/bin/datagerry -c /etc/datagerry/cmdb.conf -s
├─1566 /usr/bin/datagerry -c /etc/datagerry/cmdb.conf -s
├─1567 /usr/bin/datagerry -c /etc/datagerry/cmdb.conf -s
└─1568 /usr/bin/datagerry -c /etc/datagerry/cmdb.conf -s
Jul 03 12:53:44 server.local datagerry[1564]: File “cmdb/interface/error_handlers.py”, line 78, in bad_request
Jul 03 12:53:44 server.local datagerry[1564]: File “cmdb/interface/error_handlers.py”, line 64, in make_error
Jul 03 12:53:44 server.local datagerry[1564]: File “flask/json/init.py”, line 170, in jsonify
Jul 03 12:53:44 server.local datagerry[1564]: File “flask/json/provider.py”, line 214, in response
Jul 03 12:53:44 server.local datagerry[1564]: File “flask/json/provider.py”, line 179, in dumps
Jul 03 12:53:44 server.local datagerry[1564]: File “json/init.py”, line 234, in dumps
Jul 03 12:53:44 server.local datagerry[1564]: File “json/encoder.py”, line 199, in encode
Jul 03 12:53:44 server.local datagerry[1564]: File “json/encoder.py”, line 257, in iterencode
Jul 03 12:53:44 server.local datagerry[1564]: File “flask/json/provider.py”, line 121, in _default
Jul 03 12:53:44 server.local datagerry[1564]: TypeError: Object of type ManagerUpdateError is not JSON serializable
but when i try to stop service, it crashes
Try to stop datagerry
root@server:~# systemctl stop datagerry
× datagerry.service - DATAGERRY - Enterprise grade OpenSource CMDB
Active: failed (Result: timeout) since Wed 2024-07-03 13:12:58 CEST; 36s ago
Process: 1537 ExecStart=/usr/bin/datagerry -c /etc/datagerry/cmdb.conf -s (code=killed, signal=KILL)
Main PID: 1537 (code=killed, signal=KILL)
Tasks: 36 (limit: 4556)
Memory: 1.1G
CPU: 10min 44.168s
Jul 03 13:12:58 server.local systemd[1]: datagerry.service: Unit process 1554 (datagerry) remains running after unit stopped.
Jul 03 13:12:58 server.local systemd[1]: datagerry.service: Unit process 1559 (datagerry) remains running after unit stopped.
Jul 03 13:12:58 server.local systemd[1]: datagerry.service: Unit process 1563 (datagerry) remains running after unit stopped.
Jul 03 13:12:58 server.local systemd[1]: datagerry.service: Unit process 1564 (datagerry) remains running after unit stopped.
Jul 03 13:12:58 server.local systemd[1]: datagerry.service: Unit process 1565 (datagerry) remains running after unit stopped.
Jul 03 13:12:58 server.local systemd[1]: datagerry.service: Unit process 1566 (datagerry) remains running after unit stopped.
Jul 03 13:12:58 server.local systemd[1]: datagerry.service: Unit process 1567 (datagerry) remains running after unit stopped.
Jul 03 13:12:58 server.local systemd[1]: datagerry.service: Unit process 1568 (datagerry) remains running after unit stopped.
Jul 03 13:12:58 server.local systemd[1]: Stopped DATAGERRY - Enterprise grade OpenSource CMDB.
Jul 03 13:12:58 server.local systemd[1]: datagerry.service: Consumed 10min 44.056s CPU time.
root@server:~# ps aux | grep datagerry
datager+ 1546 0.0 2.1 473252 84612 ? Sl Jul02 0:01 /usr/bin/datagerry -c /etc/datagerry/cmdb.conf -s
datager+ 1554 0.0 1.2 781788 48916 ? Sl Jul02 0:28 /usr/bin/datagerry -c /etc/datagerry/cmdb.conf -s
datager+ 1559 0.0 2.5 437304 102112 ? Sl Jul02 0:26 /usr/bin/datagerry -c /etc/datagerry/cmdb.conf -s
datager+ 1563 0.0 2.4 437560 97296 ? S Jul02 0:12 /usr/bin/datagerry -c /etc/datagerry/cmdb.conf -s
datager+ 1564 0.1 4.5 516812 181404 ? Sl Jul02 1:52 /usr/bin/datagerry -c /etc/datagerry/cmdb.conf -s
datager+ 1565 0.1 4.9 534332 199116 ? Sl Jul02 1:49 /usr/bin/datagerry -c /etc/datagerry/cmdb.conf -s
datager+ 1566 0.1 4.9 534248 198860 ? Sl Jul02 1:54 /usr/bin/datagerry -c /etc/datagerry/cmdb.conf -s
datager+ 1567 0.1 5.0 535188 200860 ? Sl Jul02 2:01 /usr/bin/datagerry -c /etc/datagerry/cmdb.conf -s
datager+ 1568 0.1 5.0 536056 200824 ? Sl Jul02 1:54 /usr/bin/datagerry -c /etc/datagerry/cmdb.conf -s
root 195550 0.0 0.0 6612 2324 pts/1 S+ 13:14 0:00 grep --color=auto datagerry
and datagerry processes still work
Processes works after stop service
root@server:~# pgrep datagerry
1546
1554
1559
1563
1564
1565
1566
1567
1568
and next for normal start i have to first kill all processes or restart machine
Summary
root@server:~# pkill -9 datagerry
root@server:~# systemctl start datagerry
Active: active (running) since Wed 2024-07-03 13:15:37 CEST; 2s ago
Main PID: 195715 (datagerry)
Tasks: 2 (limit: 4556)
Memory: 281.2M
CPU: 2.259s
├─195715 /usr/bin/datagerry -c /etc/datagerry/cmdb.conf -s
└─195717 /usr/bin/datagerry -c /etc/datagerry/cmdb.conf -s
Jul 03 13:15:37 server.local systemd[1]: Started DATAGERRY - Enterprise grade OpenSource CMDB.
Could you check it
