Our working Datagerry installion just broke.
It seems to have broken after a client sent this api call:
PS Microsoft.PowerShell.Core\FileSystem::\\Client\C$\Users\xxxxx\Documents> \\Client\C$\Users\xxxxx\Documents\dg.ps1
results : {@{type_id=4; status=True; version=1.0.0; creation_time=2024-05-07T13:13:45.178000; author_id=1; last_edit_time=; editor_id=; active=True;
fields=System.Object[]; public_id=5}, @{type_id=4; status=True; version=1.0.0; creation_time=2024-05-07T13:13:53.132000; author_id=1; last_edit_time=;
editor_id=; active=True; fields=System.Object[]; public_id=6}, @{type_id=4; status=True; version=1.0.0; creation_time=2024-05-07T13:13:59.312000;
author_id=1; last_edit_time=; editor_id=; active=True; fields=System.Object[]; public_id=7}, @{type_id=2; status=True; version=2.0.0;
creation_time=2024-05-16T06:47:37.860000; author_id=1; last_edit_time=2024-05-21T04:50:37.484000; editor_id=1; active=True; fields=System.Object[];
public_id=8}...}
count : 10
total : 13
parameters : @{limit=10; sort=public_id; order=1; page=1; filter=; optional=}
pager : @{page=1; page_size=10; total_pages=2}
pagination : @{current=https://dg1.example.net/rest/objects/; first=https://dg1.example.net/rest/objects/?page=1;
prev=https://dg1.example.net/rest/objects/?page=1; next=https://dg1.example.net/rest/objects/?page=2;
last=https://dg1.example.net/rest/objects/?page=2}
response_type : GET
model : Object
time : 2024-06-03T10:21:04.416401+00:00
"fields": [
"value": 1,
"name": "vlan_id"
"value": "1.1.1.1/24",
"name": "cidr"
"version": "1.0.1",
"type_id": 10,
"views": 0,
"author_id": 1,
"active": true
19
Has anybody seen any of the error messages below?
Now I get this screen when I log into the web gui ( see screenshot ).
These are the log file messages when I start this up:
Jun 3 12:16:50 dg1 datagerry[23042]: [2024-06-03 12:16:50][DEBUG ] --- event received:cmdb.core.object.added (service.py)
Jun 3 12:16:50 dg1 datagerry[23059]: [2024-06-03 12:16:50][ERROR ] --- string indices must be integers (objects_routes.py)
Jun 3 12:17:39 dg1 datagerry[23042]: [2024-06-03 12:17:39][DEBUG ] --- event received:cmdb.core.object.added (service.py)
Jun 3 12:17:39 dg1 datagerry[23053]: [2024-06-03 12:17:39][ERROR ] --- string indices must be integers (objects_routes.py)
Jun 3 12:21:04 dg1 datagerry[23042]: [2024-06-03 12:21:04][DEBUG ] --- event received:cmdb.core.object.added (service.py)
Jun 3 14:39:09 dg1 datagerry[23034]: Exception ignored in: <module 'threading' from '/tmp/_MEIQvmNN7/threading.pyc'>
Jun 3 14:39:09 dg1 datagerry[23034]: Traceback (most recent call last):
Jun 3 14:39:09 dg1 datagerry[23034]: File "threading.py", line 1477, in _shutdown
Jun 3 14:39:09 dg1 datagerry[23034]: TypeError: _stop_app() takes 0 positional arguments but 2 were given
Jun 3 14:57:34 dg1 datagerry[1048961]: [2024-06-03 14:57:34][INFO ] --- DATAGERRY starting... (__main__.py)
Jun 3 14:57:34 dg1 datagerry[1048961]: [2024-06-03 14:57:34][WARNING ] --- DEBUG mode enabled (__main__.py)
Jun 3 14:57:34 dg1 datagerry[1048961]: [2024-06-03 14:57:34][INFO ] --- Checking database connection with cmdb.conf data (__main__.py)
Jun 3 14:57:34 dg1 datagerry[1048961]: [2024-06-03 14:57:34][INFO ] --- Database connection established. (__main__.py)
Jun 3 14:57:34 dg1 datagerry[1048961]: [2024-06-03 14:57:34][INFO ] --- STARTING Checks... (__check__.py)
Jun 3 14:57:34 dg1 datagerry[1048961]: [2024-06-03 14:57:34][INFO ] --- CHECK: Checking database collection validation (__check__.py)
Jun 3 14:57:34 dg1 datagerry[1048961]: [2024-06-03 14:57:34][INFO ] --- CHECK: Root Location valid (__check__.py)
Jun 3 14:57:34 dg1 datagerry[1048961]: [2024-06-03 14:57:34][INFO ] --- CHECK: Database collection validation status True (__check__.py)
Jun 3 14:57:34 dg1 datagerry[1048961]: [2024-06-03 14:57:34][INFO ] --- FINISHED Checks! (__check__.py)
Jun 3 14:57:34 dg1 datagerry[1048961]: [2024-06-03 14:57:34][INFO ] --- SETUP ROUTINE: STARTED... (__setup__.py)
Jun 3 14:57:34 dg1 datagerry[1048961]: [2024-06-03 14:57:34][INFO ] --- SETUP ROUTINE: Checking database connection (__setup__.py)
Jun 3 14:57:34 dg1 datagerry[1048961]: [2024-06-03 14:57:34][INFO ] --- SETUP ROUTINE: Database connection status True (__setup__.py)
Jun 3 14:57:34 dg1 datagerry[1048961]: [2024-06-03 14:57:34][INFO ] --- SETUP ROUTINE: FINISHED! (__setup__.py)
Jun 3 14:57:34 dg1 datagerry[1048961]: ########################################################################
Jun 3 14:57:34 dg1 datagerry[1048961]: @@@@@ @ @@@@@@@ @ @@@@@ @@@@@@@ @@@@@ @@@@@ @@ @@
Jun 3 14:57:34 dg1 datagerry[1048961]: @ @ @@ @ @@ @@@@@@@ @@@@@@@ @@@@@@ @@@@@@ @@@ @@@
Jun 3 14:57:34 dg1 datagerry[1048961]: @ @ @ @ @ @ @ @@@ @@ @@@ @@ @@ @@ @@ @@ @@
Jun 3 14:57:34 dg1 datagerry[1048961]: @ @ @ @ @ @ @ @@ @@@@@@ @@ @@ @@ @@ @@@@
Jun 3 14:57:34 dg1 datagerry[1048961]: @ @ @ @ @ @ @ @@ @@@ @@@@@@ @@@@@@ @@@@@@ @@@@
Jun 3 14:57:34 dg1 datagerry[1048961]: @ @ @@@@@@ @ @@@@@@ @@ @@@ @@@ @@@@@ @@@@@ @@
Jun 3 14:57:34 dg1 datagerry[1048961]: @ @ @ @ @ @ @ @@@ @@ @@@ @@ @@@ @@ @@@ @@
Jun 3 14:57:34 dg1 datagerry[1048961]: @ @ @ @ @ @ @ @@@@@@@ @@@@@@@ @@ @@@ @@ @@@ @@
Jun 3 14:57:34 dg1 datagerry[1048961]: @@@@@ @ @ @ @ @ @@@@@@ @@@@@@@ @@ @@@ @@ @@@ @@
Jun 3 14:57:34 dg1 datagerry[1048961]: Welcome to DATAGERRY
Jun 3 14:57:34 dg1 datagerry[1048961]: Starting system with following parameters:
Jun 3 14:57:34 dg1 datagerry[1048961]: {'keys': False, 'debug': True, 'start': True, 'config_file': '/etc/datagerry/cmdb.conf'}
Jun 3 14:57:34 dg1 datagerry[1048961]: Copyright (C) 2024 becon GmbH
Jun 3 14:57:34 dg1 datagerry[1048961]: licensed under the terms of the GNU Affero General Public License version 3
Jun 3 14:57:34 dg1 datagerry[1048969]: [2024-06-03 14:57:34][INFO ] --- start exportd ... (service.py)
Jun 3 14:57:34 dg1 datagerry[1048969]: [2024-06-03 14:57:34][INFO ] --- exportd: start run (service.py)
Jun 3 14:57:34 dg1 datagerry[1048969]: Exception in thread Thread-2:
Jun 3 14:57:34 dg1 datagerry[1048969]: Traceback (most recent call last):
Jun 3 14:57:34 dg1 datagerry[1048969]: File "threading.py", line 980, in _bootstrap_inner
Jun 3 14:57:34 dg1 datagerry[1048969]: File "cmdb/event_management/event_manager.py", line 321, in run
Jun 3 14:57:34 dg1 datagerry[1048969]: File "cmdb/event_management/event_manager.py", line 306, in __init_connection
Jun 3 14:57:34 dg1 datagerry[1048969]: File "pika/adapters/blocking_connection.py", line 2468, in queue_declare
Jun 3 14:57:34 dg1 datagerry[1048969]: File "pika/adapters/blocking_connection.py", line 1290, in _flush_output
Jun 3 14:57:34 dg1 datagerry[1048969]: File "pika/adapters/blocking_connection.py", line 458, in _flush_output
Jun 3 14:57:34 dg1 datagerry[1048969]: File "pika/adapters/select_connection.py", line 495, in poll
Jun 3 14:57:34 dg1 datagerry[1048969]: File "pika/adapters/select_connection.py", line 1114, in poll
Jun 3 14:57:34 dg1 datagerry[1048969]: File "pika/adapters/select_connection.py", line 831, in _dispatch_fd_events
Jun 3 14:57:34 dg1 datagerry[1048969]: File "pika/adapters/base_connection.py", line 410, in _handle_events
Jun 3 14:57:34 dg1 datagerry[1048969]: File "pika/adapters/base_connection.py", line 464, in _handle_read
Jun 3 14:57:34 dg1 datagerry[1048969]: File "pika/connection.py", line 2021, in _on_data_available
Jun 3 14:57:34 dg1 datagerry[1048969]: File "pika/connection.py", line 2142, in _process_frame
Jun 3 14:57:34 dg1 datagerry[1048969]: File "pika/connection.py", line 2120, in _process_callbacks
Jun 3 14:57:34 dg1 datagerry[1048969]: File "pika/callback.py", line 60, in wrapper
Jun 3 14:57:34 dg1 datagerry[1048969]: File "pika/callback.py", line 92, in wrapper
Jun 3 14:57:34 dg1 datagerry[1048969]: File "pika/callback.py", line 236, in process
Jun 3 14:57:34 dg1 datagerry[1048969]: File "pika/adapters/blocking_connection.py", line 1357, in _on_channel_closed
Jun 3 14:57:34 dg1 datagerry[1048969]: pika.exceptions.ChannelClosed: (405, "RESOURCE_LOCKED - cannot obtain exclusive access to locked queue 'datagerry.eventbus.exportd' in vhost '/'. It could be originally declared on another connection or the exclusive property value does not match that of the original declaration.")
Jun 3 14:57:34 dg1 datagerry[1048961]: [2024-06-03 14:57:34][INFO ] --- Process manager started: True (__main__.py)
Jun 3 14:57:34 dg1 datagerry[1048961]: [2024-06-03 14:57:34][INFO ] --- DATAGERRY successfully started (__main__.py)
Jun 3 14:57:34 dg1 datagerry[1048974]: [2024-06-03 14:57:34][INFO ] --- start webapp ... (service.py)
Jun 3 14:57:34 dg1 datagerry[1048974]: Exception in thread Thread-3:
Jun 3 14:57:34 dg1 datagerry[1048974]: Traceback (most recent call last):
Jun 3 14:57:34 dg1 datagerry[1048974]: File "threading.py", line 980, in _bootstrap_inner
Jun 3 14:57:34 dg1 datagerry[1048974]: File "cmdb/event_management/event_manager.py", line 321, in run
Jun 3 14:57:34 dg1 datagerry[1048974]: File "cmdb/event_management/event_manager.py", line 306, in __init_connection
Jun 3 14:57:34 dg1 datagerry[1048974]: File "pika/adapters/blocking_connection.py", line 2468, in queue_declare
Jun 3 14:57:34 dg1 datagerry[1048974]: File "pika/adapters/blocking_connection.py", line 1290, in _flush_output
Jun 3 14:57:34 dg1 datagerry[1048974]: File "pika/adapters/blocking_connection.py", line 458, in _flush_output
Jun 3 14:57:34 dg1 datagerry[1048974]: File "pika/adapters/select_connection.py", line 495, in poll
Jun 3 14:57:34 dg1 datagerry[1048974]: File "pika/adapters/select_connection.py", line 1114, in poll
Jun 3 14:57:34 dg1 datagerry[1048974]: File "pika/adapters/select_connection.py", line 831, in _dispatch_fd_events
Jun 3 14:57:34 dg1 datagerry[1048974]: File "pika/adapters/base_connection.py", line 410, in _handle_events
Jun 3 14:57:34 dg1 datagerry[1048974]: File "pika/adapters/base_connection.py", line 464, in _handle_read
Jun 3 14:57:34 dg1 datagerry[1048974]: File "pika/connection.py", line 2021, in _on_data_available
Jun 3 14:57:34 dg1 datagerry[1048974]: File "pika/connection.py", line 2142, in _process_frame
Jun 3 14:57:34 dg1 datagerry[1048974]: File "pika/connection.py", line 2120, in _process_callbacks
Jun 3 14:57:34 dg1 datagerry[1048974]: File "pika/callback.py", line 60, in wrapper
Jun 3 14:57:34 dg1 datagerry[1048974]: File "pika/callback.py", line 92, in wrapper
Jun 3 14:57:34 dg1 datagerry[1048974]: File "pika/callback.py", line 236, in process
Jun 3 14:57:34 dg1 datagerry[1048974]: File "pika/adapters/blocking_connection.py", line 1357, in _on_channel_closed
Jun 3 14:57:34 dg1 datagerry[1048974]: pika.exceptions.ChannelClosed: (405, "RESOURCE_LOCKED - cannot obtain exclusive access to locked queue 'datagerry.eventbus.webapp' in vhost '/'. It could be originally declared on another connection or the exclusive property value does not match that of the original declaration.")
Jun 3 14:57:35 dg1 datagerry[1048974]: [2024-06-03 14:57:35][DEBUG ] --- Gunicorn starting with auto reload option (gunicorn.py)
Jun 3 14:57:35 dg1 datagerry[1048974]: [2024-06-03 14:57:35][INFO ] --- Interfaces started @ http://0.0.0.0:4000 (gunicorn.py)
I have since stopped and restarted both datagerry and rabbitmq to no avail.
Ideas most welcomed.
Regards,
Kitchen Sink
