MDS takes a long time to load
Hello!
I recently started actively using MDS, and I noticed that the elements are currently loading in about 15 seconds. Are there any plans to optimize MDS in the next release?
thx.
Hi @ozzy,
thanks for the feedback, we will take a look at it.
Can you give us some metrics on how much MDS with how many objects you use?
We have a little more than 2000 objects. And we use one MDS structure in the type.
