Is it a chance to add MDS to exportd ? Especially when it comes to exporting to csv (ExternalSystemCsv)
I use MDS only in simple form this structure with one column. -
Will it be possible for MDS to appear in the list of objects?
After completing the 3 MDS structures with reference fields, it takes a long time to load the values in object. Is there a plan to optimize this?
Is it a chance in one Multi Data Sections to use few fields with references without table so that you can select different types of objects and show them one below the other?
like under on picture:
