Hello!
I have more than 20000 objects in DataGerry.
Search delay is more than 20 seconds, sometimes more than 1 minute.
Hi @avorr,
this is a known issue (many objects have a long delay) which will be fixed in the future as part of the API and Frontend optimization tasks.
Please tell me approximately when will this be?
Hello @adnan.smajic,
At the moment, this issue (long delays with a large number of objects) prevents DataGerry from being used as a fully-fledged enterprise solution. Is there hope that this problem will be resolved in the next release?
Hi @avorr,
could you provide us the Type in which you are using MDS? So we have a good example the speed optimize on.
MDS_Type.txt (8.3 KB)
Thank you very much!
Same issue here: adding new objects in a class where we have two references to other classes makes the global search unusable (the response time, which is immediate, suddenly increases to more than 1 minute)
After investigation, I found out that DataGerry creates only one single index in the MongoDB database. Therefore when reaching a certain size, the performance starts being really poor on some queries.
I have therefore created two indexes in our MongoDB:
- one on public_id, which is used everywhere in references
- one on fields.value, which is used in attributes.
The result is incredible as searches are now responding within 1 sec most of the time.
Hi @acpfn ,
thanks for the feedback, we will have a look at it.
