Improving Usability with Reference Fields
Hello!
It would be beneficial to have a mechanism where, if the target object is missing when filling out a field of type Ref, the user can create it without having to navigate to the corresponding tab. Currently, when the object to which one needs to refer in another object is absent, users have to create these objects separately and then establish the connection between them.
