Hi, can you write how to set up label in CI explorer?
Hi @dbukharev,
Thanks for your query.
What you need to do is:
Navigate to the Type whose objects you want to label.
Within that Type, go to the Meta section.
In the Meta section, select the Label that you want to display.
sincerely,
