Hi !
I try to use Docapi for exports. While configuring a new template the wizard asks for a “template type”. Is it possible to create new template types? Because it shows one preconfigured but it doesnt match my requirements.
Thx in advance! ![]()
Hi !
Hi @MatHol ,
at the current state of development only the preconfigured template type is possible.
Can you tell us more about what your requirements for templates are ?
Hi @adnan.smajic ,
I use Datagerry for handling IT-Documentations. So i was looking for an option to export a customer with all his data. I configured a Objecttype for customer and objecttypes for the hard and software. I settet a reference on every type to the customer. Now it would be great to export a report in a recursive way - customer is the root and it automaticly exports all linked objects. ![]()
Hi adnan!
Is there more Info right now about when it will be possible? ![]()
Hi @MatHol,
the Feature-Request with recursive exports is added to our Backlog but at the moment the team is focused on preparing the release of the next version. Your Feature-Request will be discussed when the next set of features is planned.
sincerly,
