Datagerry and mongo relicaset
It seams that datagerry can’t work with mongo cluster or there is some extra configuration options ?
Hello @mfominov,
Under the etc/- directory of your DATAGERRY installation you will find the configuration file cmdb.conf.
Here you can make various settings.
To answer your question. We do not yet have a possibility to realize Mongo Cluster.
With kind regards
To configure db connection i’m using env variables.
Thx.
