Change interface language
Documentation says that the interface language can be changed in the top right corner, but I can’t find that setting.
I’m using Version 3.0.0 (docker installation, like described)
Hi @Carsten,
Please note: Language selection in the interface is only available within the DataGerry Service Portal. docs.datagerry.com
If you are working inside the DataGerry application (outside the Service Portal), the language cannot be changed via your user interface at this time.
Sincerely,
Okay, got that. Thanks for your swift answer.
Another one, same direction: is it possible to adapt a corporate design (logo, color scheme…). I can’t find anything within documentation.
Hi @Carsten,
Thank you for the additional question.
Currently it is not possible to adapt the corporate design within the interface of DataGerry.
But I will submit this as a feature request at our upcoming project-management meeting and will update you afterward regarding any developments or roadmap inclusion.
Sincerely,
okay, good to know. Thanks
