Hello Dear DataGerry Team, I do not understand how to generate token for api management. Nothing is related on API in admin datagerry panel ui ? I go on a restheart solution to plug on mongodb for the moment but that is not a great thinks.
As you see my administrator panel, nothing is related to API.
Where do i can find / generate token ? I did not find what I search in DataGerry.
I think that api is running because api url answer.
Please tell me what can I do to generate and use token ?
I user docker docker-compose as below
https://docs.datagerry.com/latest/admin_guide/setup.html#docker-image
My DG version is :
“title”: “DATAGERRY”,
“version”: “1.7.2”,
“connected”: true
Thank you
Gauthier
