- First case log numbering
i write about what i saw in logs in object.
I have object which i change many times and now its number is alitle bit atypical.
The log counter has reset or does not show the correct numbering
Now i have version
i show you in a form table because picture will be too big
Table with detailed information about the object version
| Show 25 entries | |||||
| Date | Log ID | Action | Author | Version | Links |
| 05.13.2020 06:42:48 | 784 | EDIT | avatar MArcin | 1.0.0 | View |
| 05.07.2020 09:57:13 | 700 | EDIT | avatar MArcin | 2.1.9 | View |
| 05.07.2020 09:56:33 | 699 | EDIT | avatar MArcin | 2.1.8 | View |
| 04.09.2020 06:53:58 | 294 | EDIT | avatar MArcin | 2.1.7 | View |
| 04.09.2020 06:52:37 | 292 | EDIT | avatar MArcin | 2.1.6 | View |
| 04.09.2020 06:49:01 | 291 | EDIT | avatar MArcin | 2.1.5 | View |
| 04.09.2020 06:43:16 | 290 | EDIT | avatar MArcin | 2.1.4 | View |
| 04.09.2020 06:41:04 | 288 | EDIT | avatar MArcin | 2.1.3 | View |
| 04.09.2020 06:38:47 | 287 | EDIT | avatar MArcin | 2.1.2 | View |
| 04.09.2020 06:37:44 | 286 | EDIT | avatar MArcin | 2.1.1 | View |
| 04.09.2020 06:34:39 | 285 | EDIT | avatar MArcin | 2.0.1 | View |
| 03.25.2020 07:15:12 | 133 | EDIT | avatar MArcin | 2.0.0 | View |
| 03.20.2020 13:19:48 | 66 | EDIT | avatar MArcin | 1.0.0 | View |
| 03.17.2020 14:55:44 | 5 | CREATE | avatar Rem | 1.0.0 | View |
The case is that see:
3 times version 1.0.0
from version 2.1.9 changed to version 1.0.0
i can’t compare from this place current with older
- Second case false information in a particular log
As you see:
in this log id 784 i change:
not very relevant information
start date from date 17/03/2020 changed to null
end date from date 13/08/2020 changed to 02/03/2020
company from empty change to 13/08/2020 - but it is impossible be done (this field is references field) and this field is still empty (in version 1.0.0 and 1.0.1- current) -i added this field recently.
I have in this object 1 or 2 more similarly incorrect information so this is no
- Third case don’t see the version to compare
When i clicked view log in version 2.0.1 i can compare and could choose from those:
but i don’t see current version 1.0.1 my object
from list logs i don’t see too current version
no log for this object has been removed
