Hey,
just wanted to share my Traefik-configuration to get DATAGERRY working with Traefik-Reverseproxy v2.
version: "3.0"
services:
nginx:
image: nethinks/nginx:latest
ports:
- 8443:80
labels:
- "traefik.enable=true"
- "traefik.http.routers.${servicename}.entrypoints=http"
- "traefik.http.routers.${servicename}.rule=Host(`${Domainname}`)" # Just add your domain-name between ``
- "traefik.http.middlewares.${servicename}-https-redirect.redirectscheme.scheme=https"
- "traefik.http.routers.${servicename}.middlewares=${servicename}-https-redirect"
- "traefik.http.routers.${servicename}-secure.entrypoints=https"
- "traefik.http.routers.${servicename}-secure.rule=Host(`${Domainname}`)" # Just add your domain-name between ``
- "traefik.http.routers.${servicename}-secure.tls=true"
- "traefik.http.routers.${servicename}-secure.tls.certresolver=http" #This may have to change to your certificate-resolver
- "traefik.http.routers.${servicename}-secure.service=${servicename}"
- "traefik.http.services.${servicename}.loadbalancer.server.port=${port}"
- "traefik.docker.network=proxy"#This may have to change to your traefik-network
- "traefik.http.routers.${servicename}-secure.middlewares=secHeaders@file" #This file may not exist in your configuration
networks:
- proxy
- default
depends_on:
- datagerry
environment:
NGINX_LOCATION_DEFAULT: "/;/;http://datagerry:4000"
restart: unless-stopped
datagerry:
image: nethinks/datagerry:latest
depends_on:
- db
- broker
environment:
DATAGERRY_Database_host: "db"
DATAGERRY_MessageQueueing_host: "broker"
db:
image: mongo:4.2-bionic
volumes:
- mongodb-data:/data/db
- mongodb-config:/data/configdb
broker:
image: rabbitmq:3.8
volumes:
- rabbitmq-data:/var/lib/rabbitmq
volumes:
rabbitmq-data:
mongodb-data:
mongodb-config:
networks: #Change this to your traefik-network
proxy:
external: true
Im using an .env-file for the configuration, so please change it to your variables or check my comments.
