I have this issue where i have the special control “Location” added to my type “clients” and “rooms” are declared but i can’t filter for a room while selecting.
It’s important because if a room is added afterwards the list is not sorted so I need the possibility of filtering/searching.
List of Rooms selectable:
Now trying to filter:
And with a structure control: “Reference” this is possible. So i think it’s a bug.
Also a short note: In daily work the sort by id is less important. More often I need sort by “Summary”-Field or “Label in location tree”. As mentioned before: If I add a Room in one building here and one building there this becomes a sorted but unsorted list. ![]()
