“Checkbox” in type edit don’t have any field about value “default” but if some object type use this type of field when i create some object i see default button.
Is should it work that?
Similar is with Reference in type edit but there i have field about value “default” unfortunately when i try check drop-down list it don’t show any results (and I have in “service” type objects.)
I can show You how i see that :
Next case
I think that when I have not set the value in the “default” field, the button when I create should not appear.
