Bulk Change changes way to much
Hello there,
I have the problem, that using the “Bulk Change” Feature: it erases other fields.
Here an example:
And for the sake of demonstration i am changing the name for both objects:
and the Preview is like this:
But while the Name is changed succesfully all other fields will be cleared…
Like here is Serialnumber now empty. In our Productive-Objects all fields, even from other sections where empty afterwards.
We are running 3.3.0 OnPremise. And there is no multi data section in these types.
Michael
Hi @MichaelW,
Thank you for reporting this. I will dig into this and get back to you as soon as possible.
Sincerely,
Hi @MichaelW,
Thanks for the detailed report and the screenshots!
This has already been fixed in our development version and will be part of the next release.
Sincerely,
Hello Abdullah-Khalid,
I think this is a major issue and I need to breef my colleagues to not use this feature to prevent dataloss.
When is the release? Will there be a sooner minor release with bugfixes?
This will help a lot.
best regards
Michael
Hello @MichaelW,
We are planning the next release at the end of next week. I’ll let you know here as soon as it’s available.
Sincerely,
