Hi everyone, I’m new to Datagerry. I followed the developer guide to set it up, but when I navigate to the localhost:4200/framework/relation endpoint I’m redirected to localhost:4200/error/404. How can I fix this? Thank you for your help!
Hi @alexdang
Thanks for reporting this!
Could you please try again with the latest development version? It should be working now.
Best Regards,
Abdullah Khalid
Thank you for the earlier fix. I’ve run into a new issue with the search feature:
When I perform a search, results are returned, but I can’t click on them or press Enter to open the selection. Could you take a look?
Thanks for reporting this! This is a known issue, and we’re currently tracking it under the Jira ticket DAT-463. we will have a look at it.
Best Regards,
Abdullah Khalid
