I am currently utilizing the ExternalSystemExecuteScript job with the “Run Export Job on Event” setting. However, I have encountered an issue where the job does not initiate when there are changes to an existing object of the source type. It functions correctly when objects are added or removed, but not when they are modified.
Is this a bug? What needs to be adjusted in the configuration so that the job responds to changes in existing objects?
datagerry: 2.2.0
mongodb: 6.0.17
