Hello together,
i got the following scenario:
- I have an object with a field that references to another object
- I navigate to the referenced object
- In the view of the referenced object there is a tab “Referenced by” in the lower area
- although there is a specification “Summary” for the entries stored there, “Summary” is not resolved
I would be very pleased if this view is corrected / extended.
FYI: I’m using the Docker image of the “nethinks/datagerry:latest” - pull just made on friday.
Thank you very much in advance!
Hello @Jennifer,
the resolution of the ‘Summary’ fields has already been corrected with operation [NET-887].
You can pass --force-recreate to docker compose up, which should use fresh containers.
Other options:
- all volumns are emptied → docker volume prune
- all image etc. will be emptied → docker system prune -a
To be on the safe side, I would recommend you to make a backup
Create backup:
sudo docker exec <mongodb container> sh -c 'mongodump --archive' > db.dump
Restore backup:
sudo docker exec -i <mongodb container> sh -c 'mongorestore --archive' < db.dump
We hope you will find the above comments helpful.
Hello there,
in the version of 1.5.3 it seems ok, but the summary field has still another problem.
I’m not sure whether I should create a new bug for this or whether the problem goes hand in hand with this bug.
Mentally I am at this point in the scenario described before:
- In the view of the referenced object there is a tab “Referenced by” in the lower area.
The “Summary” field is now displayed. The problem is that if a reference is stored in the summary, only the number of the reference is displayed. I would expect that the number is then also resolved.
Do you see it the same way?
Kind regards
