Summaries for reference object in object type
i check in version 1.6.1 and 1.6.2 and don’t work
i have list object:
next i change summaries for flagship company and backup company in object type:
before change:
after change:
and before change:
after change:
and save changes for object type:
Next i look for list of objects:
And i see only first value in Backup company but i choose 2 values
Hello @marcinw,
thank you for your feedback. There seem to be problems when two references are created in one selction. We need to take a closer look at this.
https://nethinks.atlassian.net/browse/NET-1055
With kind regards
Hello @sergej.dumler,
Next what i saw and its a problem in Summary:
even thought i don’t mark Label for summary i got it
example:
and
and in objects list
and from object view
another thing is the order of the fields in the summary
and from objects list i see:
So the correct order set by the user is not taken into account
Please fix both errors because they are important
I think I know the reason for the first point from my post above.
it work only for first reference field in type of object.
example
i have 2 different reference fields: Flagship company, Supplier
and for the first field in the order in the object type it works (Flagship company), and for the second field in the order and further (Supplier) the setting Label
or next position (field) in summary
when i unseted or other type of object I did not setfirst reference field but set some next, Summary don’t show as i want
What do You think?
Can you fix it?
in version 1.6.3 for first look it work now
in the course of further verification, it will come out whether everything works as planned
