i think a generic *SQL interface could be a nice way for exportd to integrate in a lot of external IT systems.
A lot of IT Systems use relational Databases like MariaDB, PostgresSQL and SQlite (yes… and MSSQL) to store Object-Data. It also can also be a multi-purpose interface for e.g. syncing data to a SQL backend for OTRS CMDB, asterisk-realtime or freeradius and many many more!
This could be the driver to enable DataGerry to achieve world domination.
hrm… i think it’s hard to think about any tools and database model that can be integrated with a SQL exporter scheme.
But, in the end of the day everything is about simple 2-dimensional tables. The question is on which side you want to do the job to map komplex data to these tables!
What are the options:
the database consists of one or more complete unnormalized tables -> Easy job because every value can be mapped 1:1 to a table.field tuple.
the database consists of a lot of normalized tables: Now there are two choices:
a) you can create views in the SQL Server to map multiple normalized tables to a single unnormalized view.
b) the mapping to the database model can be performed by DataGerry itself. In this case some sort of “Object Relational Mapper” function has to be implemented into DataGerry.
I think by implementing a ORM, DataGerry would be capable to do any sync job you think about. But even with a simple 1:1 Field mapping and the use of SQL views it shold be possible do perform a wide range of jobs.
