Possible typo on DataGerry systemd definition
While troubleshooting the exportd functionality with a script not working i checked the internal of the systemd definition of datagerry as shown below:
[Unit]
Description=DATAGERRY - Enterprise grade OpenSource CMDB
Wants=rabbitmq-server.service mongod.service
Requires=network.target
After=rabbitmq-server.service mongod.service network.target
[Service]
UserModel=datagerry
Group=datagerry
Type=simple
ExecStart=/usr/bin/datagerry -c /etc/datagerry/cmdb.conf -s
KillMode=process
Restart=on-failure
[Install]
WantedBy=multi-user.target
Is this the intended definition or should the UserModel be renamed to User?
By using the UserModel definition there is no match and the service is run as root, which renaming it to User it is run as datagerry, which I think was the intended way.
Thanks for the info. Something must have gone wrong with some automatic renaming. We will fix that.
