In latest time you change view from tab “Referenced by” and it looks good. Type i see in other column so form me is a good solution.
In that place i see only Summary and it is great.
Could You change the same in objects list view and in object view in 2 places?
Now unfortunately you can see all the information in the field (column).
example:
see in column Flagship company:
Type, Public ID, and Summary.
Is it possible change like in tab “Referenced by” in object view and see only Summary what is underlined with a blue pen on screenshots?
I think information such as from could be displayed when hovering over a field in a balloon when you hover over the field with the mouse or in preview.
example:
The most is change see only Summary without Type and Public ID in objects list view and in object view
