logs with create user
[2020-10-26 06:33:07][DEBUG ] — [AuthModule][__init_settings] Installed provider: <class ‘cmdb.security.auth.providers.internal_providers.LocalAuthenticationProvider’> (init.py)
[2020-10-26 06:33:07][DEBUG ] — [AuthModule][__init_settings] Database provider list: [{‘class_name’: ‘LocalAuthenticationProvider’, ‘config’: {‘active’: True}}, {‘class_name’: ‘LdapAuthenticationProvider’, ‘config’: {‘active’: True, ‘default_group’: 2, ‘server_config’: {‘host’: ‘HOST.DOMAIN_NAME.COM’, ‘port’: 389, ‘use_ssl’: False}, ‘connection_config’: {‘user’: ‘CN=USER,OU=ADDITIONAL_ACCOUNTS,OU=ACCOUNT_GROUP,OU=CENTRAL_OTHER,OU=DOMAIN,DC=DOMAIN_NAME,DC=COM’, ‘password’: ‘PASSWORD’, ‘version’: 3}, ‘search’: {‘basedn’: ‘DC=DOMAIN_NAME,DC=COM’, ‘searchfilter’: ‘(uid=%username%)’}}}] (init.py)
[2020-10-26 06:33:07][DEBUG ] — [AuthModule][__init_settings] Installed provider: <class ‘cmdb.security.auth.providers.external_providers.LdapAuthenticationProvider’> (init.py)
[2020-10-26 06:33:07][ERROR ] — [AUTH] case121212 not in database: User not found (init.py)
[2020-10-26 06:33:07][INFO ] — [AUTH] Check for other providers - request_user: case121212 (init.py)
[2020-10-26 06:33:07][DEBUG ] — [AUTH] Provider list: [<class ‘cmdb.security.auth.providers.internal_providers.LocalAuthenticationProvider’>, <class ‘cmdb.security.auth.providers.external_providers.LdapAuthenticationProvider’>] (init.py)
[2020-10-26 06:33:07][DEBUG ] — [AUTH] using provider: <class ‘cmdb.security.auth.providers.internal_providers.LocalAuthenticationProvider’> (init.py)
[2020-10-26 06:33:07][INFO ] — [LocalAuthenticationProvider] Try login for user case121212 (internal_providers.py)
[2020-10-26 06:33:07][ERROR ] — [AUTH] User case121212 could not validate with provider <class ‘cmdb.security.auth.providers.internal_providers.LocalAuthenticationProvider’>: (‘LocalAuthenticationProvider’, ‘Error while GET operation - E: $User not found’) (init.py)
[2020-10-26 06:33:07][INFO ] — [AUTH] Provider instance: <cmdb.security.auth.providers.internal_providers.LocalAuthenticationProvider object at 0x7fe59827cb00> (init.py)
[2020-10-26 06:33:07][DEBUG ] — [AUTH] using provider: <class ‘cmdb.security.auth.providers.external_providers.LdapAuthenticationProvider’> (init.py)
[2020-10-26 06:33:07][DEBUG ] — [LdapAuthenticationProvider] Connection status: True (external_providers.py)
[2020-10-26 06:33:07][DEBUG ] — [LdapAuthenticationProvider] Search Filter: (uid=case121212) (external_providers.py)
[2020-10-26 06:33:10][DEBUG ] — [LdapAuthenticationProvider] Search result: True (external_providers.py)
[2020-10-26 06:33:10][WARNING ] — [LdapAuthenticationProvider] User exists on LDAP but not in database: User not found (external_providers.py)
[2020-10-26 06:33:10][INFO ] — [LdapAuthenticationProvider] Try creating user: case121212 (external_providers.py)
[2020-10-26 06:33:10][DEBUG ] — [LdapAuthenticationProvider] New user was init (external_providers.py)
[2020-10-26 06:33:10][DEBUG ] — [AuthModule][__init_settings] Installed provider: <class ‘cmdb.security.auth.providers.internal_providers.LocalAuthenticationProvider’> (init.py)
[2020-10-26 06:33:10][DEBUG ] — [AuthModule][__init_settings] Database provider list: [{‘class_name’: ‘LocalAuthenticationProvider’, ‘config’: {‘active’: True}}, {‘class_name’: ‘LdapAuthenticationProvider’, ‘config’: {‘active’: True, ‘default_group’: 2, ‘server_config’: {‘host’: ‘HOST.DOMAIN_NAME.COM’, ‘port’: 389, ‘use_ssl’: False}, ‘connection_config’: {‘user’: ‘CN=USER,OU=ADDITIONAL_ACCOUNTS,OU=ACCOUNT_GROUP,OU=CENTRAL_OTHER,OU=DOMAIN,DC=DOMAIN_NAME,DC=COM’, ‘password’: ‘PASSWORD’, ‘version’: 3}, ‘search’: {‘basedn’: ‘DC=DOMAIN_NAME,DC=COM’, ‘searchfilter’: ‘(uid=%username%)’}}}] (init.py)
[2020-10-26 06:33:10][DEBUG ] — [AuthModule][__init_settings] Installed provider: <class ‘cmdb.security.auth.providers.external_providers.LdapAuthenticationProvider’> (init.py)
[2020-10-26 06:33:10][DEBUG ] — Excepted parameter: group_id | public_id (route_utils.py)
[2020-10-26 06:33:10][DEBUG ] — Parameter exits 2 (route_utils.py)
[2020-10-26 06:33:10][DEBUG ] — Exception parameter passed test at group_id | public_id! (route_utils.py)
