Help in setting up filters on ExternalSystemCsv
Hello Everyone! :smiley:
Today i was testing the ExternalSystemCsv capabilities and it works great.
The only problem occurred is that i have a “Type” called “Linux server” and in this type i have IP address belonging to multiple subnets… some starts with 10.4.. others with 10.20.. and so on…
1
Now i would be interested in filtering (for that type) only network addresses starting with 10.4.
Everything esle works great but i can’t solve this, is there any “jolly character”?
beacuse leaving it blank doesn’t work and also using * doesn’t work too…
Thanks in advance for your help!
:slight_smile:
Hello @Marco,
currently regex statements are not supported in this place.
We have created a process for this.
https://nethinks.atlassian.net/browse/NET-974
Thank you for your suggestion.
Hello @Marco,
the release will solve your problem.
