Exportd - can't run job
Today i found some bug in datagerry v1.6.3 in exportd.
When user with right wants to run job manualy it cannot and this user saw communicate:.
User have rights like this
and these rights not small
or like this:
Please verify this problem or write me solution if i have got mistake in my rights for this user.
Best Regards
MArcin
Hi @marcinw,
The following rights are necessary to use the Exportd:
base.framework.object.view
base.framework.type.view
base.framework.category.view
base.framework.log.view
base.user-management.user.view
base.user-management.group.view
base.docapi.template.view
Every which you wrote and more
base.system.view
base.framework.object.*
base.export.object.*
base.exportd.job.view
base.exportd.job.run
base.exportd.log.view
base.exportd.log.reload
i have rights like these upper and can’t run job manualy got popup
Hello @marcinw,
it’s a bug. To solve the problem in the frontend, the right is still needed:
base.exportd.job.*
The problem here is that the right does not restrict the REST calls for the exportd.job.
The behaviour will be fixed in the next bugfix release.
I checked in new version 1.6.4 on one user and i think that it work :slight_smile:
