i Can’t add document in Tab Explorer
Reproduce:
Click tab Explorer -> 2. choose Folder -> 3. click button Upload -> 4. see popup Attachments -> 5. I select, move and drop the file -> 6. this file don’t added, now button X and Done are grey and i can’t click and leave from popup (only refresh page (F5) help) so i can’t add file and can’t leave from popup to datagerry
Click tab Explorer -> 2. choose Folder -> 3. click button Upload -> 4. see popup Attachments -> 5. I select, move and drop the file -> 6. click to upload -> 7. see catalog from i can choose file -> 8. choose one document -> 9. click button Open -10. this file don’t added, now button X and Done are grey and i can’t click and leave from popup (only refresh page (F5) help)
thanks for reporting that issue. Unfortunately I cannot reproduce that in our testing environments. Can you please give us some more informations about your environment?
Which browser do you use? Does it happen in multiple browsers?
Can you see any error messages in your browser’s console (Java Script console)
Can you see any error messages in the DATAGERRY backend?
request entity is too large
but files had only 1,2MB or second 1,5 MB
in backend i don’t saw any information.
When i tried before i can’t on both instances datagerry save files to application but on second instance today i was able to save in application (i mark 2 files together, held, moved to popup and dropped to instance in chrome) strange in one instance work in second not work. i have to check what is different.
few days ago i had update on server maybe this worked? i will keep checking.
Maybe, once a configuration change was made to work properly that needs to be changed after release in other tools (like nginx, rabbit, mongo) to application work properly, one could write in a section Annoucement what is required to change in these tools, or reference for configuration.
I think that if users once created a server with a configuration for the application and everything works, they do not change the configuration of the tools and it is worth informing them about the change;)
This will help everyone and make it easier to informate changes would be important information for current users
