Dear all
Please consider the creation of an option to reference an object through the linking of a reference child objects.
For example there could be an asset which will need to reference a location.
Rather than entering the location manually the parent reference could be a region e.g. EU and the location would be the children of this reference e.g. Germany, Italy, France, etc
A limit of 2 or 3 child references would be the best way forward in most situations.
Thank you
Best Regards
Konstantinos Betsis
The creation of references between objects is managed in the type generator.
https://docs.datagerry.com/latest/admin_guide/framework.html#adding-editing-an-object-type
To do this, you must drag the corresponding fields into the configuration in the Type Generator under the tab ‘Basic Information’. You will find the reference fields under the item ‘Special Controls’.
Best Regards
Sergej Dumler
Hi @sergej.dumler
The request is more in terms of parent child references.
So ideally we would have two types:
a. Region
b. Country
When we create an object we would like to reference countries depending on the region.
So when EU is selected only countries within the EU will be available for selection.
In the current format a user will have to select the region e.g. EU, and then the country regardless of the region, which will be a huge drop down.
The only way we have found to accelerate this is by typing the EY object ID as to return only objects with a parent that region.
A more integrated reference model will greatly enhance user experience.
