Deactivated objects
Situation:
i have 3 companies
and i use these in other objects of type as reference
i have enable only active objects
Now i deactivated one object “Company 1”
and then i still see information about “Company 1” in reference fields
the same is from object view
and next export
export to excel
public_id active name completed flagship-company backup-company testing-reference-field wybor start-date end-date data password firma-field
231 True Cleaning in Munich True None 643 347 value1 2020-05-20 00:00:00 2020-05-25 00:00:00 118
645 True Cleaning in Krakow True 118 119 value2 2020-05-20 00:00:00 2020-05-25 00:00:00 None
742 True Cleaning in Munich True 118 119 value1 2020-05-20 00:00:00 2020-05-25 00:00:00 None None
and next exportd
exportd to csv
Task to do;Completed;Flagship Company;Backup Company;Start Date;End Date;Opis
Cleaning in Munich on 3th street;;Company 3 Gil Person; ;2020-06-02 00:00:00;2020-06-05 00:00:00;”test1
test2
test3”
ds;False; ; ;2020-01-01 00:00:00;;”text
text
text”
Cleaning in Munich;True;Company 1 Person TRd;Company 2 Test Tes;2020-05-20 00:00:00;2020-05-25 00:00:00;”Bla bal
dsll dss
dk ddss
Jeden jeden
Dwa dwa
Trzy trzej
Cztery czterej”
test2
test3”
Cleaning in Krakow;True;Company 1 Person TRd;Company 2 Test Tes;2020-05-20 00:00:00;2020-05-25 00:00:00;” test1 test1
test2 test2
test3 test3”
Cleaning in Pila;True;Company 1 Person TRd;Company 2 Test Tes;2020-05-20 00:00:00;2020-05-25 00:00:00;” test1 test1
test2 test2
test3 test3”
It should be 2 options for user what he decide:
  • hide data from fields which have this object as reference (in case of user wants activate again object then object should be still in objects reference fields or object is temporary deactivated)
  • remove data from fields which have this object as reference
If you don’t want get choose for users i think better will be hidde data
Of course if edit object and change data in reference field to other active object then is should normal see)
If you have off “only active objects”
hidden information should be visible but should be marked somehow cuz to distinguish them from these active references in objects
in version 1.6.3
Still if object is off and set as reference object in the field in other object then this object which is off is still visible and when is exported to file still shows this object but not should.
This is very imprtant for cmdb please fix it
