DataGerry stops working when adding 2 types in a reference field
Hello folks,
previously i have been using version 1.5.3 with many categories and types and objects created.
In that version i was able to assign one reference field to multiple types, so for example, if i had a field called “password” and this field was having a reference field called “assigned to” then i was able to select “desktop PC”, “laptop” and so on.
Now after the upgrading to 1.6.1 version i noticed that when editing a reference field trying to assign more than one type, i got DataGerry crashing to database connection page. It’s impossible for me to edit the field.
Is it a known behaviour?
Thanks so much in advance.
Hello @Marco ,
Thank you very much for your comment. The behaviour is known and is being processed.
Kind regards
