DataGerry not starting using docker image
i tried your docker-compose.yml from the getting started guide and i end up with the errors below…
The exact same thing happens if i deploy to my kubernetes cluster…
docker logs datagerry_datagerry_1
[2020-04-14 15:09:03][INFO    ] --- DATAGERRY starting... (__main__.py)
[2020-04-14 15:09:03][INFO    ] --- Checking database connection with cmdb.conf data (__main__.py)
[2020-04-14 15:09:04][INFO    ] --- Database connection established. (__main__.py)
[2020-04-14 15:09:04][INFO    ] --- CHECK ROUTINE: STARTED... (__check__.py)
[2020-04-14 15:09:04][INFO    ] --- CHECK ROUTINE: FINISHED! (__check__.py)
[2020-04-14 15:09:04][INFO    ] --- SETUP ROUTINE: STARTED... (__setup__.py)
[2020-04-14 15:09:04][INFO    ] --- SETUP ROUTINE: Checking database connection (__setup__.py)
[2020-04-14 15:09:04][INFO    ] --- SETUP ROUTINE: Database connection status True (__setup__.py)
[2020-04-14 15:09:04][INFO    ] --- SETUP ROUTINE: initialize database cmdb (__setup__.py)
[2020-04-14 15:09:04][INFO    ] --- SETUP ROUTINE: initialize finished (__setup__.py)
[2020-04-14 15:09:04][INFO    ] --- SETUP ROUTINE: Generate rsa key pair (__setup__.py)
[2020-04-14 15:09:04][INFO    ] --- KEY ROUTINE: Generate RSA keypair (__setup__.py)
[2020-04-14 15:09:05][INFO    ] --- KEY ROUTINE: Generate aes key (__setup__.py)
[2020-04-14 15:09:05][INFO    ] --- SETUP ROUTINE: Checking database connection (__setup__.py)
[2020-04-14 15:09:05][INFO    ] --- SETUP ROUTINE: Database connection status True (__setup__.py)
[2020-04-14 15:09:05][INFO    ] --- KEY ROUTINE: Password was updated for user failed:  (__setup__.py)
[2020-04-14 15:09:05][INFO    ] --- KEY ROUTINE: FINISHED (__setup__.py)
[2020-04-14 15:09:05][INFO    ] --- SETUP ROUTINE: User management (__setup__.py)
[2020-04-14 15:09:05][ERROR   ] --- Something went wrong during the generation of the user management.
 Error: admin (__main__.py)
[2020-04-14 15:09:05][WARNING ] --- The setup did not go through as expected - Status SetupStatus.ERROR (__main__.py)
Welcome to DATAGERRY
Starting system with following parameters:
{'keys': False, 'test_data': False, 'debug': False, 'start': True, 'config_file': '/etc/datagerry/cmdb.conf'}
Copyright (C) 2019 NETHINKS GmbH
licensed under the terms of the GNU Affero General Public License version 3
[2020-04-14 15:09:07][INFO    ] --- DATAGERRY starting... (__main__.py)
[2020-04-14 15:09:07][INFO    ] --- Checking database connection with cmdb.conf data (__main__.py)
[2020-04-14 15:09:07][INFO    ] --- Database connection established. (__main__.py)
[2020-04-14 15:09:07][INFO    ] --- CHECK ROUTINE: STARTED... (__check__.py)
[2020-04-14 15:09:07][INFO    ] --- CHECK ROUTINE: Checking database collection validation (__check__.py)
[2020-04-14 15:09:07][INFO    ] --- CHECK ROUTINE: Database collection validation status True (__check__.py)
[2020-04-14 15:09:07][ERROR   ] --- The section updater does not exist! (__check__.py)
[2020-04-14 15:09:07][WARNING ] --- The current database version does not match the valid database version. (__check__.py)
[2020-04-14 15:09:07][INFO    ] --- CHECK ROUTINE: FINISHED! (__check__.py)
[2020-04-14 15:09:07][INFO    ] --- UPDATE ROUTINE: Update database collection (__update__.py)
[2020-04-14 15:09:07][INFO    ] --- SETUP ROUTINE: Checking database connection (__update__.py)
[2020-04-14 15:09:07][INFO    ] --- SETUP ROUTINE: Database connection status True (__update__.py)
Process:[#################---------------------------------] 33%        | [1/3]
[2020-04-14 15:09:07][WARNING ] --- This method is likely to be deprecated soon! (wraps.py)
[2020-04-14 15:09:07][ERROR   ] --- Something went wrong during the generation of the updater module.
 Error: 'NoneType' object is not subscriptable (__main__.py)
[2020-04-14 15:09:07][WARNING ] --- The update did not go through as expected - Status UpateStatus.ERROR (__main__.py)
[2020-04-14 15:09:10][INFO    ] --- DATAGERRY starting... (__main__.py)
[2020-04-14 15:09:10][INFO    ] --- Checking database connection with cmdb.conf data (__main__.py)
[2020-04-14 15:09:10][INFO    ] --- Database connection established. (__main__.py)
[2020-04-14 15:09:10][INFO    ] --- CHECK ROUTINE: STARTED... (__check__.py)
[2020-04-14 15:09:10][INFO    ] --- CHECK ROUTINE: Checking database collection validation (__check__.py)
[2020-04-14 15:09:10][INFO    ] --- CHECK ROUTINE: Database collection validation status True (__check__.py)
[2020-04-14 15:09:10][ERROR   ] --- Please run an update. There are new updates available.Current Updater Version: 0 Newest Update Version: 20200408 (__check__.py)
[2020-04-14 15:09:10][WARNING ] --- The current database version does not match the valid database version. (__check__.py)
[2020-04-14 15:09:10][INFO    ] --- CHECK ROUTINE: FINISHED! (__check__.py)
[2020-04-14 15:09:10][INFO    ] --- UPDATE ROUTINE: Update database collection (__update__.py)
[2020-04-14 15:09:10][INFO    ] --- SETUP ROUTINE: Checking database connection (__update__.py)
[2020-04-14 15:09:10][INFO    ] --- SETUP ROUTINE: Database connection status True (__update__.py)
[2020-04-14 15:09:10][WARNING ] --- This method is likely to be deprecated soon! (wraps.py)
[2020-04-14 15:09:10][ERROR   ] --- Something went wrong during the generation of the updater module.
[2020-04-14 15:09:10][WARNING ] --- The update did not go through as expected - Status UpateStatus.ERROR (__main__.py)
[2020-04-14 15:09:12][INFO    ] --- DATAGERRY starting... (__main__.py)
[2020-04-14 15:09:12][INFO    ] --- Checking database connection with cmdb.conf data (__main__.py)
[2020-04-14 15:09:12][INFO    ] --- Database connection established. (__main__.py)
[2020-04-14 15:09:12][INFO    ] --- CHECK ROUTINE: STARTED... (__check__.py)
[2020-04-14 15:09:12][INFO    ] --- CHECK ROUTINE: Checking database collection validation (__check__.py)
[2020-04-14 15:09:12][INFO    ] --- CHECK ROUTINE: Database collection validation status True (__check__.py)
[2020-04-14 15:09:12][ERROR   ] --- Please run an update. There are new updates available.Current Updater Version: 0 Newest Update Version: 20200408 (__check__.py)
[2020-04-14 15:09:12][WARNING ] --- The current database version does not match the valid database version. (__check__.py)
[2020-04-14 15:09:12][INFO    ] --- CHECK ROUTINE: FINISHED! (__check__.py)
[2020-04-14 15:09:12][INFO    ] --- UPDATE ROUTINE: Update database collection (__update__.py)
[2020-04-14 15:09:12][INFO    ] --- SETUP ROUTINE: Checking database connection (__update__.py)
[2020-04-14 15:09:12][INFO    ] --- SETUP ROUTINE: Database connection status True (__update__.py)
[2020-04-14 15:09:12][WARNING ] --- This method is likely to be deprecated soon! (wraps.py)
[2020-04-14 15:09:12][ERROR   ] --- Something went wrong during the generation of the updater module.
[2020-04-14 15:09:12][WARNING ] --- The update did not go through as expected - Status UpateStatus.ERROR (__main__.py)
[2020-04-14 15:09:15][INFO    ] --- DATAGERRY starting... (__main__.py)
[2020-04-14 15:09:15][INFO    ] --- Checking database connection with cmdb.conf data (__main__.py)
[2020-04-14 15:09:15][INFO    ] --- Database connection established. (__main__.py)
[2020-04-14 15:09:15][INFO    ] --- CHECK ROUTINE: STARTED... (__check__.py)
[2020-04-14 15:09:15][INFO    ] --- CHECK ROUTINE: Checking database collection validation (__check__.py)
[2020-04-14 15:09:15][INFO    ] --- CHECK ROUTINE: Database collection validation status True (__check__.py)
[2020-04-14 15:09:15][ERROR   ] --- Please run an update. There are new updates available.Current Updater Version: 0 Newest Update Version: 20200408 (__check__.py)
[2020-04-14 15:09:15][WARNING ] --- The current database version does not match the valid database version. (__check__.py)
[2020-04-14 15:09:15][INFO    ] --- CHECK ROUTINE: FINISHED! (__check__.py)
[2020-04-14 15:09:15][INFO    ] --- UPDATE ROUTINE: Update database collection (__update__.py)
[2020-04-14 15:09:15][INFO    ] --- SETUP ROUTINE: Checking database connection (__update__.py)
[2020-04-14 15:09:15][INFO    ] --- SETUP ROUTINE: Database connection status True (__update__.py)
[2020-04-14 15:09:15][WARNING ] --- This method is likely to be deprecated soon! (wraps.py)
[2020-04-14 15:09:15][ERROR   ] --- Something went wrong during the generation of the updater module.
[2020-04-14 15:09:15][WARNING ] --- The update did not go through as expected - Status UpateStatus.ERROR (__main__.py)
[2020-04-14 15:09:19][INFO    ] --- DATAGERRY starting... (__main__.py)
[2020-04-14 15:09:19][INFO    ] --- Checking database connection with cmdb.conf data (__main__.py)
[2020-04-14 15:09:19][INFO    ] --- Database connection established. (__main__.py)
[2020-04-14 15:09:19][INFO    ] --- CHECK ROUTINE: STARTED... (__check__.py)
[2020-04-14 15:09:19][INFO    ] --- CHECK ROUTINE: Checking database collection validation (__check__.py)
[2020-04-14 15:09:19][INFO    ] --- CHECK ROUTINE: Database collection validation status True (__check__.py)
[2020-04-14 15:09:19][ERROR   ] --- Please run an update. There are new updates available.Current Updater Version: 0 Newest Update Version: 20200408 (__check__.py)
[2020-04-14 15:09:19][WARNING ] --- The current database version does not match the valid database version. (__check__.py)
[2020-04-14 15:09:19][INFO    ] --- CHECK ROUTINE: FINISHED! (__check__.py)
[2020-04-14 15:09:19][INFO    ] --- UPDATE ROUTINE: Update database collection (__update__.py)
[2020-04-14 15:09:19][INFO    ] --- SETUP ROUTINE: Checking database connection (__update__.py)
[2020-04-14 15:09:19][INFO    ] --- SETUP ROUTINE: Database connection status True (__update__.py)
[2020-04-14 15:09:19][WARNING ] --- This method is likely to be deprecated soon! (wraps.py)
[2020-04-14 15:09:19][ERROR   ] --- Something went wrong during the generation of the updater module.
[2020-04-14 15:09:19][WARNING ] --- The update did not go through as expected - Status UpateStatus.ERROR (__main__.py)
[2020-04-14 15:09:24][INFO    ] --- DATAGERRY starting... (__main__.py)
[2020-04-14 15:09:24][INFO    ] --- Checking database connection with cmdb.conf data (__main__.py)
[2020-04-14 15:09:24][INFO    ] --- Database connection established. (__main__.py)
[2020-04-14 15:09:24][INFO    ] --- CHECK ROUTINE: STARTED... (__check__.py)
[2020-04-14 15:09:24][INFO    ] --- CHECK ROUTINE: Checking database collection validation (__check__.py)
[2020-04-14 15:09:24][INFO    ] --- CHECK ROUTINE: Database collection validation status True (__check__.py)
[2020-04-14 15:09:24][ERROR   ] --- Please run an update. There are new updates available.Current Updater Version: 0 Newest Update Version: 20200408 (__check__.py)
[2020-04-14 15:09:24][WARNING ] --- The current database version does not match the valid database version. (__check__.py)
[2020-04-14 15:09:24][INFO    ] --- CHECK ROUTINE: FINISHED! (__check__.py)
[2020-04-14 15:09:24][INFO    ] --- UPDATE ROUTINE: Update database collection (__update__.py)
[2020-04-14 15:09:24][INFO    ] --- SETUP ROUTINE: Checking database connection (__update__.py)
[2020-04-14 15:09:24][INFO    ] --- SETUP ROUTINE: Database connection status True (__update__.py)
[2020-04-14 15:09:24][WARNING ] --- This method is likely to be deprecated soon! (wraps.py)
[2020-04-14 15:09:24][ERROR   ] --- Something went wrong during the generation of the updater module.
[2020-04-14 15:09:24][WARNING ] --- The update did not go through as expected - Status UpateStatus.ERROR (__main__.py)
Hi @erSitzt,
and welcome to our community. Thanks for reporting that issue. As this was a critical bug, we fixed that immediately and made a bugfix release. Please try our new version 1.1.4. Thanks again for reporting that bug.
Thanks a lot, deployment is working now ! :slight_smile:
