Hey,
i noticed some inconvenience
when i create few subcategories for categroy “test” on the left side i see these subcategories but are not in they are not sorted alphabetically or as I would like, but they are in the order in which I created them from the end, i.e. :
c
e
a
b
d
i can’t change these sequence from any place.
I think it could be exist in category -> child category / subcategory and where i could change it position with use mouse.
There is already something in the program in the types part when I create type fields / edit type fields and I can move them as I want and in my own order. that would be great because now I can’t change their order unless I delete the subcategories and create them again in good order or edit their names in order. Which is also not very comfortable.
A minor matter
i have some category. It is “test” and type “testowy”. When i edit this category i see someting like this:
thanks for reporting this. Currently, the categories in the menu are sorted by ID (which is not very nice, I see), the types within the categories are sorted alphabetically. The “search type” box will filter object types that are shown in the menu (e.g. a filter for “net”, will show all types that includes the string “net” in the label).
I think, we should do some work for the object menu, to improve the usability for a near future release of DATAGERRY. Below, I collected some issues for that, but feel free, to add some further ideas to this thread.
from my side:
I think that like i wrote earlier in this this topic
Category i would like to see every subcategories assigned to this category and as in edit type i could move these subcategories.
Look at this screens:
I would like to that similiar.
Imagine that:
Structure is a Subcategories
“test” fields are subcategories
and then you could change their position at your own discretion
You don’t need
but only: for move this subcategory
and for remove/move subcategory and then this subcategory exists like a category.
good news for that topic. We finished [NET-401] to make categories and types within categories sortable. This feature will be released in 1.3.0 (at 21st August 2020).
