I found next bug, i think this is quite a big problem, viz:
In one of type i create two pools which are references to the same type:
because i need it to dataguard in oracle
and next i create some object which has primary cluster of oracle and standby cluster of oracle.
From this object i see two cluster like i want.
In this moment i have problem, because:
if i go to link for first cluster “Primary” i see in tab “Referenced by” at the down of the page i object type Dataguard which I created a moment ago
but if i go to link for cluster on second position “Standby” i don’t see anything
Please fix this bug.
allow one object to create several references to one of the same objects. This is often very necessary
if i change reference one references to other type of object then you can see the references correctly again, but that’s not the point.
